I did install a new upgraded magnetic TPS on the ETM with no success, absolutely no change in symptoms. All other sensors have been checked with scanner (not VIDA) and are working consistently and all fuses are good. The car WAS throwing codes relative to the accelerator pedal soo I removed it and found a scratch on the sensor face (pedal side not pluged side). So my question, does anyone have experience with this? And would a scratch on the pedal potentiometer casue the problems mentioned above? Below is a picture of the petal sensor.
Throttle issue 02' v70 2.4 n/a
Itschetmanly31
- Year and Model: 2002 v70
Itschetmanly31
Yes I did a thorough clean on the TB although it wasn't very dirty to begin with. In addition, replaced the TB gasket.
Itschetmanly31
I'm really not tech savvy. I'm thinking about looking up a local guy with access to VIDA software to perform a check. But thanks for the video
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
good idea, I'm not a tech type either.Itschetmanly31 wrote: 07 Sep 2025, 07:03 I'm really not tech savvy. I'm thinking about looking up a local guy with access to VIDA software to perform a check. But thanks for the video
I know it uses 2 methods to generate throttle signal, digital and analog, they have to be a close match or it will go into limp mode.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
02 has the ETM? I thought that was only 01. Rest are ETB
04s60 2.4
04xc70 2.5t
04xc70 2.5t
Itschetmanly31
Not sure if its ETB or ETM its the larger clunky TB with the yellow sticker.
Update: after taking for a test drive I think im dealing with a fuel pump issue it gives many symptoms of failing pump or regulator unit. The car has never engaged limp mode witch is a big indicator of a failed TB. I can still drive the car and it responds to throttle input. I will test pressure and post results later
- br0dy519
Gotcha. I would make sure you don't have any vacuum leaks as well. Those have always caused fuel-like symptoms for me.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
Itschetmanly31
Found a vacume leak and she's back to normal. Initially I found a vacume leak, fixed and had no change in symptoms. I did the fuel pressure test and that's when I found the OTHER broken vacume line lmao. SMH it was a simple fix all along, the car adjusted back to normal idle after just a few seconds
- 866 Views
- 3258 Views
Last post by vmaxmike
- 3751 Views
- 1001 Views
Last post by Vancethevolvo
- 14 Replies
- 4394 Views
Last post by NathansC70
