2004 XC70 Cross Country No Throttle
RaynormusT
Year and Model: 2004 xc70
Post by RaynormusT »
Took my newly acquired 2004 XC70 out the other day and had no throttle at all.....car started and would idle but no response from the throttle. I tried the throttle body re-learn (key on, depress pedal slowly, release pedal slowly, repeat 3-4 times key off start car.......nothing) Removed t-body and cleaned butterfly. We are going to replace the MAF and T-body this evening.....Any other thing I should look for?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Check gas pedal assembly...
RaynormusT
Is this a known problem?
Has thanked: 1610 times
Been thanked: 4068 times
No. The electronic throttle actuator on the P2 chassis is very reliable
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
turn ignition on and listen, you should hear the TB test cycle, a couple of clicks.
