S60 2001 Electric seat no longer works after 30s door opening
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
samgav
Year and Model: S60 2001
Post by samgav »
Hello, I'm French and I apologize in advance for any typos because I use Google Translate.
So, I'm having a problem with my driver's power seat. I can get it to work for 30 seconds after opening the door, then nothing after that.
Before, I could adjust the seat even while driving, but now I can't.
I do have 12V coming to the module under the seat. I disconnected the green connector, leaving the black tip of the multimeter on the black wire of the gray connector next to the green connector. With the red tip of the multimeter, I tested each pin of the module and found no voltage.
Is the problem with the module under the seat, a relay, or a fuse?
Photo du module https://ibb.co/rRHJcSf8
Thank you in advance for your help.
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
Hello.
1. Focus on power supply to the module.
2. Get yourself an incandescent test light(you can make yourself one, but better buy one from local autoparts store or amazon).
3. Start the car and wait until seat will no longer move.
4. With car running check power supply to the grey connector with your test light. You should backprobe it(connector attached and you are using needles or t-pins to get contact). It should light bright. If no light-verify your test light working(check on battery)and if good, verify contacts. If still no light- your issue is with prior to connector.
5. If the light is bright and the seat is not moving- turn off the car. Remove Grey connector. Inspect if the connector pins are not spread or show signs of corrosion. Can try to tighten connectors with small screwdriver or properly remove from connector and tighten.
6. Reinstall connector. If no improvement-module is your likely problem.
7 check local salvage yard for one, sometimes it is cheaper to buy entire seat than 1 module.
Thats where I would start. Good luck
Has thanked: 1498 times
Been thanked: 3810 times
There might be software that inhibits sent movementwhile driving. The Germans would never let you do that. My 2005 allows seat movement 30 seconds after key off, then it stops. Sounds like software?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
abscate wrote: 20 Sep 2025, 02:45 There might be software that inhibits sent movementwhile driving. The Germans would never let you do that. My 2005 allows seat movement 30 seconds after key off, then it stops. Sounds like software?
my 04 v70 can move seats anytime the key is in run, driving or parked.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
My '07 seats move anytime, even without the key in the car, driving and parked. Must be a regional software thing.
2003 XC 70 (sold)
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
Bonjour Monsieur ca va (thats nearly all my French) Im going to Paris in March so i need to practice. Did you use your multimeter at the fuse ? if there is no 12v there im not sure what is the problem. You may need to run a similar size wire from the fuse box as a "work around"
darylrobert
Could be a relay, working at first then overheating. search for power seat relay location
jonesg
Post by jonesg »
jonesg
Post by jonesg »
darylrobert wrote: 21 Sep 2025, 19:06 Could be a relay, working at first then overheating. search for power seat relay location
could also be the seat memory module, if using a different key it will migrate to the memory set for that key and remain there unless the program button is pressed to re-position the seat.
The buttons are in a bad location for spills and getting clogged up, considering the controls do work briefly...I would look at that.
Window gets left open and rain gets in there..etc.
I posted links to the test proceedures and seat circuit diagram for 2001 s60 from CHARM.
