Sticky buttons broken mounting plastic F to C swap
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
To change your ECC from F to C is easy, just unclip the face plate. To remove and clean sticky buttons properly (i used chemicals),first remove electronics PCB,it comes out with the temp sensor (needs a good pull). Then press the buttons with a large screwdriver from the back. Do not try and do this for the buttons, the white sliding tabs will break.I found prising with a screwdriver from the front got them out unscratched and unbroken (see pic 2)
update F to Celsius
update F to Celsius
broken ecc 1.jpg (81.86 KiB) Viewed 157 times
removing sticky buttons
This passengers LHD temp knob is broken, still works but knob lost its notching and had severe wobbles
LHD temp knob broken
temp knob broken.jpg (51.09 KiB) Viewed 156 times
