Hello, can I use the XC90 drive shaft carrier bearing support on XC 70 2002 2,4 t 147 kw? The only difference I see is that I need to drill another hole for the bearing. On the XC90, one screw hole is further than on the XC70 bracket, and a different bearing type is used.
https://www.fcpeuro.com/public/assets/p ... 1736284036 site carrier bearing support
volvo xc70 drive shaft carrier bearing bracket
