P0014 code on my 2004 XC70 Topic is solved
RaynormusT
- Year and Model: 2004 xc70
Hello fellow Volvo people. I keep getting a P0014 code on my 2004 XC70. It usually is thrown at first start up in the morning and causes multiple dropped cyl. After clearing the codes, the car runs fine and will restart fine after the car is warmed up. Any ideas? TIA.
Reason: improved Subject
It is a 'cam reset valve' (VOlvo term) or cam solenoid error on the exhaust cam.
- Incorrect cam belt timing
- dirty Cam reset valve (VVT solenoid)
- dirty oil or poor oil performance
- Bad VVT hub
- Bad VVT hub
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Inspect the VVT solenoids, especially the exhaust one. You need a new gasket for each: https://www.fcpeuro.com/products/volvo- ... z-30731212 It is not uncommon for mesh filter in this gasket to clog.
Absolutely don't over-tighten the bolts! They don't take much to torque, like 10 Nm. You may lift up the surface around threads and then you'll have an oil leak.
RaynormusT
Ok...so I removed, cleaned and re-gasketed the exhaust VVT solenoid. Doesn't seems to have made a difference. My question is, Should I also do the intake side VVT solenoid? The exhaust did seem sticky before I cleaned it. It only throws the code on start up.
- Has thanked: 2199 times
The valves can also go bad. With the ridiculous cost of new ones, Look for a used one or junkyard that may have one to swap in.
Check the resistance across the pins. should be pretty low. I can't recall the range but 4-6 ohms or less?
vtl
OP says they were sticky, most likely teflon liner deteriorated and gummed up. Goes to trash bin.scot850 wrote: 10 Oct 2025, 08:30 The valves can also go bad. With the ridiculous cost of new ones, Look for a used one or junkyard that may have one to swap in.
I think it’s 27 ohms spec. Testing resistance is a necessary but not sufficient test for good function
- 1001 Views
Last post by clifford06
- 1749 Views
- 2989 Views
Last post by northern_dweller
- 32 Replies
- 8357 Views
Last post by SoCalV70T5
- 1616 Views
Last post by jonesg
