850 Petrol fuel tank question
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Guys,
2 years ago, i had to change brakes hoses hidden behind the fuel tank, to be able to succeed to have my french MOT. Unfortunatly, i couldn't change the second one. The old one was in good shape, so everything went fine. I had to move the tank.
Since then i can't fill the thank till the top cause some hose may have been unplugged by the operation, and i loose gasoline on the ground.
Here's the picture of my 850 model FT.
May someone tell me which hose i may have unplugged unfortunately ?
I do thank who will explain me this issue.
Manov
850 Fuel tank.png (329.25 KiB) Viewed 121 times
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Can you tell anything from looking at the tank from underneath ? I had a problem with part #12.
You could also look at the top of the tank through the access plate where the fuel pump is.
1999 V70 GLT
