I always dread doing the plugs on a Volvo 5 cylinder engine. P80's are not too terrible in NA or turbo form, but P2's are a royal pain as you have to remove the cross pipe to remove the cover.
I've just swapped the plugs (and also the coils) on our son's 2006 XC70. The car is just past the mileage (about 128k miles) for the the scheduled plug swap. It had the first set done at Volvo about 14 years ago at about 6ok miles (96kkm large service).
The reason I dread doing the plugs is not cylinders 1,2,3 and 5. They are straight forward. Every P80 and P2 I have done the plugs on #4 cylinder is a major pain as the plug always gets really tight and I have to work it in and out using a little WD-40 to get the plug out. It has taken me up to an hour to do the one plug successfully as I am paranoid the threads will strip.
So what is it about cylinder #4? Why is always the worst one to remove?
I swapped the plugs and planned to reuse the coils due to the relatively low mileage. However, as usual all the coils had a crack in the body below the boot down to the plastic plug cover tube. I have seen the crack part way, but these were all the way down. They still performed well but I had a new set sitting in a box bought for this car maybe 10 years ago!
Anyone else have this issue and can explain why #4 is a bear?
What is it with white block engines and cylinder #4?
- Has thanked: 2197 times
- Been thanked: 1851 times
- Been thanked: 4064 times
Esteemed colleague. Symbol for 4 is symbol of death
In China, sometimes there is no fourth floor of a building ..
- IMG_0194.jpeg (9.05 KiB) Viewed 293 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I've done plugs on my 850 one time, but don't recall an issue with #4. I've got plugs to do it again, so I'll pay closer attention this time around.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Yikes! For me or the car??
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I don't know Neil. I have done quite a few plug changes on white blocks, but never experienced what you are describing.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 2854 times
- Been thanked: 1332 times
Neil I also never noticed anything with #4.
And anytime I get to post a clip from the best movie ever made, based on the best book ever written, I don't hesitate.
The missing floor is in reference to the number 13 being unlucky. This is foreshadowing that Carson Wells will be unlucky.
In the US this was often the case with floors and even airliner rows. I've seen both. [EDIT] with the number 13 [/EDIT]abscate wrote: 08 Oct 2025, 01:23 Esteemed colleague. Symbol for 4 is symbol of death
Reason: forgot an important piece of info, doh!
I think a lot of the issue is the length of time the newer plugs are in the engine between service mileage swaps. In our case for the 06 XC70, the plugs were last swapped in around 2012? With the older cars I swapped the plugs more frequently and in those, after the first set, I didn't have the issue. Difference between regular servicing and overdue catch up servicing.
- Has thanked: 987 times
- Been thanked: 1075 times
I was going to comment after reading the first post:
"You just need to inspect or change your plugs more often."
But I would never be so crass.
volvolugnutr
volvolugnutr
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I have changed several sets of plugs on p80s and P2s. Ive never had a problem with #4.
It’s one of the reasons I eschew Pt and Ir plugs on my cars. It would take me 20 years to get to 100k on my T4, and so on. Coppers from FreeCP are what I run and the hardest part is keeping track of which plugs are replacements so I stay honest with Scott.
I got to use “ eschew” in a sentence!
- 2146 Views
Last post by Danius
- 387 Views
Last post by darrylrobert
- 14 Replies
- 2526 Views
Last post by RickHaleParker
- 1290 Views
Last post by nickjggreen
- 1458 Views
Last post by dm635
