The following is from a Google (AI) search — the NAPA clerk insists they're all the same.
Google answer to the question above:
"No, it's not recommended to add any coolant dye to Zerex G-05, as the dye is irrelevant to the coolant's chemical performance. Zerex G-05 is a hybrid organic acid technology (HOAT) coolant that already contains a dye that can change color based on the system it's in. Adding another dye can interfere with the coolant's performance.
Dye color is misleading:
Coolant color is not an indicator of its chemical technology, and different technologies can have the same color. For example, Zerex G-05 is a HOAT coolant, while OAT coolants also exist."
So, I'm hesitating.
is any coolant dye good with Zerex G05?
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
That sounds like AI is confused to the usage of the dye, to me. I'm not sure I've heard of dye for coolant, Though. If it's available, and I needed it, I wouldn't hesitate to put it in G05 unless the dye said not to.
I've never been in a situation where I thought a dye would do anything for me. If I have a leak, I either wait until it's big enough to easily see, or I use a pressure tester, and make it leak when cold, and look and listen for it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Today there was a puddle on the pavement where the car was parked for about half an hour. Looks like the water pump which is not too old really, with maybe around 40k miles. Gotta get the wheel off and have a closer look.
I emailed the support line at Valvoline that owns Zerex G05, got no response. The chat line at least responded but the person said there are too many products to keep track of so they don't suggest any. Not helpful—but the lead does look like the wp so I won't need the dye anyway, but still it would be good to know.
- 339 Views
- 987 Views
Last post by vtl
- 1970 Views
Last post by MDK
- 701 Views
Last post by RickHaleParker
- 807 Views
Last post by JimBee
