Lack of power and code 640c v70 2006 Topic is solved
ChristianNS240
Year and Model: V70 2006
Has thanked: 1 time
Post by ChristianNS240 »
Hi I don't know much, but this morning my v70 2.5t 2006 gave me the messege reduced engine power or something alog those lines and the dtc code 640c. It had a lack of power.
When I look under the Hood I found that a pcv pipe had a crack in it and when I touched it ,it broke of. So I wonder if these two things are connected.
Has thanked: 2197 times
Been thanked: 1850 times
Vacuum or boost leak. If you have a leak like you have, it is likely the issue. It throws a code for anything that is in the intake air system when you get a leak.
