05-07 xc90 DIY Repair Costs vs non-bastard P80 Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
Compared to a -98 P80, how high are the DIY repair costs of a 2.5T XC90? Common problems or fixes under the XC94M say keeping up with general maintenance is really all that's needed, but there must be stuff that breaks. I'm trying to figure out what those repair costs would be.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Motor is straight forward, if you know the transverse I4/I5/I6 cylinder then it's pretty easy to maintain with PCV service and oil trap and timing belt as the required maintenance items. Water pump and alternator here and there but my '05 ran great on the day I sold it in 2021 with 200+k miles. XC90 5 cylinder has two VVT hubs, they can wear out over time and start leaking oil from the front camshafts.
General area for common maintenance with the Gen1 XC90 is front suspension. High centered 4500 lb vehicle, you'll see wear from control arms and spring seats at a higher rate than a sedan for instance. Sometimes shocks as well. This is more or less a 100k mile thing.
I've owned an XC90 since 2005, have two at home as I write. Follow what others are doing, make some investment in decent quality parts, change fluids (all fluids) with some desgree of regularity and do the nominal maintenance in the book at or before it's due. That would be my advice if you're thinking to pick up an XC90.
- CIK7
Thank you so much!ggleavitt wrote: 23 Oct 2025, 22:04 Motor is straight forward, if you know the transverse I4/I5/I6 cylinder then it's pretty easy to maintain with PCV service and oil trap and timing belt as the required maintenance items. Water pump and alternator here and there but my '05 ran great on the day I sold it in 2021 with 200+k miles. XC90 5 cylinder has two VVT hubs, they can wear out over time and start leaking oil from the front camshafts.
- Been thanked: 504 times
I used to have 1998 V70 and 1998 S70. Currently has P2 S60 and XC90...
Engine maintenance costs (Timing belt, WP, spark plugs etc): similar.
Suspension: struts, shocks, control arms etc cost about 20%-30% more for the XC90. Probably from fewer XC90 than S60.
VVT Hub about $350-$400 but you only need to do it once.
- 19 Replies
- 5482 Views
- 1300 Views
Last post by wizechatmgr
- 468 Views
Last post by velorider
- 1459 Views
- 6053 Views
