Just checking to make sure here, but my while driving my car's wheel is slightly cocked to the right. The car drives straight while the steering wheel is slightly to the right in it's natural state.
I just bought the car a month ago and the tires were new so there's no significant wear pattern on them yet. I'm just checking to see if I should go ahead and get a full alignment done since the steering wheel is off-center even the car itself drives normally?
Off-Center Wheel - Alignment? - 97 854 t-5
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
If it does not annoy you leave it until you need to get an alignment done. Personally, I don't like my wheel to be like that. It is a sign of a botched alignment job. Any alignment should be done to both sides equally to keep the wheel right.
Before airbags it didn't matter too much, we just pulled the steering wheel off and re-aligned that.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Mostly, yea it is an annoyance issue, but I was assuming that the steering wheel being off like that meant it needed an alignment anyway? So if I'm reading what you're saying, you just mean that until the car is pulling one way or the other or until i get new tires I shouldn't be worried about the alignment?billofdurham wrote:If it does not annoy you leave it until you need to get an alignment done. Personally, I don't like my wheel to be like that. It is a sign of a botched alignment job. Any alignment should be done to both sides equally to keep the wheel right.
Bill.
- billofdurham
If you can't feel any adverse effects on the steering and don't see any unusual tyre wear it will go until you need to get it done.
Bill.
Bill.
Previously:
Previously:
If it annoys you enough, the factory manual posted at the top of the forum says you can adjust it.Black850 wrote:Just checking to make sure here, but my while driving my car's wheel is slightly cocked to the right. The car drives straight while the steering wheel is slightly to the right in it's natural state.
Under Pre-alignment Checks, it says, "6) If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts."
Larry
Li'l Red Wagon
97 855 GLT
Li'l Red Wagon
97 855 GLT
- billofdurham
That is what should have been done on the alignment. I don't think it is a DIY job, bearing in mind the laser equipment now in use for alignment, and they can still be out.
Bill.
Bill.
Previously:
Previously:
srnkanator
- Year and Model:
Done a bounce test on your struts/shocks? After ten years they could be shot . . .
slightly modded 850 T.... ;0
2010 XC60 T6 AWD
2005 S60 2.5 T
2010 XC60 T6 AWD
2005 S60 2.5 T
you can remove the steering wheel and center it. i just did it. make sure you unplug the battery first. if you dont, you will get the srs light. it is a simple operation. two torx bolts in the back and one center one for the wheel itself. i dont remember the sizes. once completed, you wont feel annoyed anymore. i drove like that after i had my acc evap core serviced. they put on the steering wheel wrong and off about 5 degrees. they gave me a great deal so i didnt want to say ' you need to fix it". anyway, good luck.
JRL
- Year and Model: Several
- Been thanked: 16 times
Do NOT leave it like that.
While it may "feel" like it's fine it may have the toe whacked out of adjustment.
I could be just a poor alignment job but why go with that assumption as if it is out you will suffer poor tire wear very soon
- 2289 Views
Last post by Baptiste1106
- 1226 Views
Last post by WillieEvans
- 456 Views
- 3651 Views
Last post by MadeInJapan
- 1185 Views
Last post by chrafael
