Hi all, I am hoping somebody may have had this problem and knows what it is.
With full steering lock, accelerating slowly, there is a low rumble sound seeming to come from the rear end. Does not happen when not accelerating, Does not happen when the weather is cold, 32 farenheight, until the car warms up. Does not happen whien steering at a less tight steering angle or normal driving. Could it be the differential not unlocking? or the Haldex pump?
Many thanks
Marc
2016 XC 70
Haldex? 2016 xc70 Topic is solved
- Has thanked: 2856 times
- Been thanked: 1332 times
I would expect a bump feel from the inside wheel if it's not unlocking, beyond just a sound.
rangema
- Year and Model: 2016 Volvo XC70
- Has thanked: 1 time
Changed over to winter tires this morning and could see no problems, the rear wheels are free to rotate so You are right.matthew1 wrote: 31 Oct 2025, 16:04 I would expect a bump feel from the inside wheel if it's not unlocking, beyond just a sound.
I discoonnected the awd module fuse #29 in glove box and all vibrations and bumps ceased. Haldex pump??
Cheers
Marc
Hm. Or this...
- 1181 Views
Last post by jimmy57
- 1452 Views
Last post by mrscullini
- 1605 Views
- 5357 Views
Last post by vtl
- 1198 Views
