PCV system problem 04 S60 2.5t
volvoporvida
- Year and Model: 2004 Volvo S60 2.5T
I did the glove test after warm up and lo and behold filled up the glove with air. I replaced oil trap, hose, banjo bolt you name it in 2021 except the Crankcase Breather Pipe Assembly. Can it be time already. I haven’t hit 100k not even close! Any suggestions?
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
May be you should look at that pipe that run from the banjo bolt in the intake to the pipe assembly.
They often clog or break. You could save money just by using the pipe from a S80 P/N 30731007
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
- 2571 Views
Last post by mickjenkins
- 1274 Views
- 15 Replies
- 3819 Views
- 51 Replies
- 9076 Views
Last post by erikv11
- 1130 Views
Last post by mika
