Hello,
Need wiring diagram for gear shifter harness to CEM or TCM, the shifter is not registered in P position.
The P position is registered via CAN and TCM, I assume wiring or gear shifter sensor are at fault, but before dismantling the shifter assy or checking the whole length of the harness I would like to check if the shifter position sensor is working.
The error code is P081C23.
Please help, thank you.
DTC P081C23 TCM not getting P Shifter position
- 3132 Views
Last post by 2001downunderxc70
- 885 Views
Last post by yoyon
- 7866 Views
Last post by oragex
- 1348 Views
Last post by RickHaleParker
- 1904 Views
Last post by greentrout
