Volvo ignition coil... don't crack it like I did
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I was looking for something to do on the 850 so I decided to clean the terminals to the original coil (Volvo PN 1275174)... I know this is not really required or perhaps even advisable. I was just tinkering on a sunny morning. When I loosened the positive nut, the whole bolt and terminal twisted too, and I saw I had cracked the case.
Fortunately I had a spare used coil (Bosch branded, Volvo PN 3507934) from a 1996 turbo sedan at the junkyard, so I installed that
The used coil required longer bolts because it has thicker mounting flanges. New bolts are 16mm long M6, compared to original 12mm long
Just offering up a summary of experiences this morning... probably the best thing to do is don't try to loosen the terminals to the coil unless there is a good reason.
- Has thanked: 2199 times
Can the old coil be repaired with plastic weld adhesive? If it still works, then it just needs the crack sealed and reinforced
Can't take the Scotsman out................
- Has thanked: 311 times
- Been thanked: 817 times
I've sure got a spare coil or two if you need one.
Nope, don't need any. I think I have at least one spare, and no -98 car to fit it to.
You could probably test the continuity on the coil to see if the electrical connection broke. If good , fill with JB Weld and clamp it shut. Good spare. I’ll do that for you if you want for karmic points
- 14 Replies
- 9122 Views
- 854 Views
Last post by fixer333
- 1144 Views
- 14 Replies
- 3663 Views
Last post by mrbrian200
- 18 Replies
- 3216 Views
Last post by URDRWHO
