Swapped passenger doors and only interior lights work
ibs740
Year and Model: V70 2004
Been thanked: 2 times
Post by ibs740 »
Hi all,
I swapped in a door from a 2001 V70, 2.4NA, automatic onto my 2004 V70, 2.4NA 5sp. Everything worked with the old door.
With the new door in place and wiring harness connected only the interior lights will work when the door is opened or closed. The mirror doesn't work, the outside temperature displays 2 dashes, the locking/unlocking doesn't work on the new door. Is there a simple fix or do I need to swap out wiring harnesses, components? The new door harness connector has a couple of extra pins but has pins in the same location as the old door.
ibs740
Post by ibs740 »
Hi, The internet of things told me to look at the DDM. I swapped in my old DDM and like magic I have a fully functioning door that doesn't have a massive rust hole in it.
Has thanked: 2210 times
Been thanked: 1852 times
I may be wrong, but if I recall there was a change in the DDM in 04, which may explain the issue. There are those that say the parts are not interchangeable. They need to be programmed to the car. I have never done that so cannot confirm that either.
Well done!
Has thanked: 1611 times
Been thanked: 4075 times
This thread sure points to DDM being car-specific...
See my note above on the DDM for 01 and 04 being different part numbers.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 94 times
Post by DavidE7 »
I put two 2004 XC70 right side doors onto a 2001 V70 and found that the wiring harnesses and switch modules has to stay with the 2001 V70.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I tried to replace the passenger side door switch of a 2001 V70 base on a 2001 V70 T5. It would not work.
