Rust prevention in front doors on V70
ibs740
Year and Model: V70 2004
Been thanked: 2 times
Post by ibs740 »
I have swapped out 2 doors (drivers and passengers) because of salt getting behind the mid height door trim....the door ding saver.
Volvo has a hole through the door skin at the front of the moulding so that salt can migrate in behind the door skin. Even is you oil spray (I do like crazy) eventually you will see the paint bubble and the door is done.
2 approaches;
I've successfully done both.
1. Pop the trim and seal the hole then use 3M double sided trim tape to reattach.
2. tape off a narrow band between the door paint and the moulding and use a high quality sealer/caulking (I've used seam sealer successfully). #2 is by far the fastest. I did #1 after noticing a tiny paint bubble under the moulding where the mounting hole is.
Designing a hole under a door moulding is as bad a design as access to the low/high beams on a 2005+ P2 V70. Yes did that yesterday.
Has thanked: 2199 times
Been thanked: 1852 times
Agreed with your thoughts on this. Any through holes on a door behind a trim is not a great idea. The paint gets shipped when the screw goes trough or a clip is pushed through. I am going to try Bilt Hamber products/sprays to protect the inner parts of the doors now it is available in Canada.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Spray with Noxudol 700, it creeps inches away, into any and every crevice. Made in Sweden.
