upstream O2 sensor - is this coolant? - 01 V70XC
saq
Year and Model: 86 740 / 06 XC70
Post by saq »
Just replaced the upstream O2 sensor on the 2001 V70XC (because of engine code). Pulled it out an am a little unsure of the look of the sensor - could just be "this is what they look like after 200k miles" or could be something wrong (though it doesn't seem to be "gunky" enough for coolant leak).
I am a bit more concerned because this car was giving me lots of misfires at startup over the summer, but pulling the car keys off of all my other keys (actually splitting it into 3 more manageable rings) made that and the "no throttle response" issue go away, so I don't think it was from a damaged head gasket. Oil also shows no signs of coolant contamination (and vise-versa), and while I did have to top up the coolant a bit recently the cap wasn't sealed so may have just evaporated off.
Seems closer to silicone really, but I haven't used any silicone on the car.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
mine looked like that at 230K miles, it still does.
Has thanked: 1611 times
Been thanked: 4074 times
Absolutely normal for an in use OXS
saq
Post by saq »
Ah good, thank you - many pictures I see out there must be of much younger sensors.
