Hello,
I had an inspection done a XC90 V8 I'm considering purchasing. These were the photos the shop provided with the text:
"During the inspection, we observed a noticeable leak from the timing cover
seal. Additionally, there are other areas beneath the engine exhibiting signs
of fluid presence, though we were unable to identify specific sources at this
time."
I know timing cover leaks are a known issue, any guesses as to the other with the unidentifiable source?
V8 Oil / Fluid Leaks
- 99TurboBrick
- Year and Model: 1999 S70 T5 Manual
- Has thanked: 42 times
- Been thanked: 15 times
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Might be old PS fluid, might be a seeping water pump, might be from the oil cooler, there's really nothing other than that to leak. I see folks write about RMS issues but in my estimation those are rare and most are misdiagnosed PS pump leaks. Timing cover is seeping versus outright leaking, that's a good thing. You could always scope the back CB shaft valley if you're really doing this assessment in detail, see if there's a hole or not- https://www.swedespeed.com/threads/new- ... ft.666250/
Does not look bad at all TBH, seep progression is reasonable for the motor.
- 2968 Views
- 1562 Views
Last post by Tkollars
- 1548 Views
Last post by tryingbe
- 17 Replies
- 6577 Views
Last post by ezeefixauto
- 1143 Views
