02 s80 2.9 twin, oil leaking
02S8029
- Year and Model: 2002 S80 2.9 T6
- Has thanked: 1 time
I started to notice oil & looked at it from under & oil is leaking from the rear left side cant find where cause too much in the way, thinking turbo? just not sure, any help is grateful. First Volvo so all new to me
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Usual suspect would be turbo oil return line. O-ring at the bottom cant last forever and needs periodic replacement. Never done it on 2.9, but cant imagine it being much "fun". Parts are probably $10, but without lift it is an interesting journey from above relying on your dexterity and praying for top bolts not to fall..
02S8029
Well thank you for that info, only good thing about the bolts is that it has been in the garage and taken care of very well so. It leaks like crazy as well cant even see the turbo from top or bottom, you recommend from under cause I do have a lift for use. Thanks again
- 1349 Views
Last post by June
- 2445 Views
Last post by nyc1836
- 1088 Views
Last post by abdomar528
- 1593 Views
Last post by 02S8029
- 58 Views
