High beams randomly switching on itself
svetjana
Year and Model: 1994 850
Been thanked: 2 times
Post by svetjana »
Recently had this problem that my high beams randomly goes on. Is this common symptom in these cars and where should I look for? Could it be just relay?
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I haven't heard of this symptom before. The closest description I could find:
viewtopic.php?t=40098
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I think the switch may have gone bad. I have had to replace a couple headlight switches on other cars at high mileage because they started to malfunction.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Not on my Volvo, but on my Cadillac... the high beams would come on with my right hand turn signal. Apparently, the switch shorts internally. It suddenly started doing it, and got worse over a period of a couple of weeks. I pulled the high beam fuse until I could get a new headlight-switch/turn-signal-stalk installed.
I've never had a Volvo headlight switch out before. I wonder if it could be disassembled and cleaned. I did have to do that with my truck many years ago. That was a dome light problem. If you do, do that... don't lube it with Vasoline, like I did. It melts.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 2199 times
Been thanked: 1852 times
The actual headlight switch was a recall issue many years ago for the units failing and causing random issues.
Try to find a junkyard one and swap it in and see if that fixes the issue.
Another other issue can be the stalk itself. The contacts can become worn or dirty. It is worth removing and cleaning the contacts.
svetjana
Post by svetjana »
Seems like it worked when I opened headlight relay and soldered some bad connections. On Monday it happened at least 5 times, on tuesday one time when driving to work. But at work i did this and to this day it hasnt happened. I will reply asap if it comes back.
