Front Passenger Door Window Switch Question
volbul2
Year and Model: 2004 XC70
Has thanked: 1 time
Been thanked: 2 times
Post by volbul2 »
The passenger door handle of my 04 P2 broke right off so I ordered a replacement from Erie Volvo. I'm wondering if I have to swap the window switch since its just the passenger side and not the master window switch on the driver's side. And if so, how do you remove the passenger switch? Its different set up from the driver's side which you just push out. Thanks in advance.
Switch 1.jpg (63.04 KiB) Viewed 370 times
Switch 2.jpg (81.98 KiB) Viewed 370 times
04 Volvo XC70 5L 145k Ruby Red (acquired 9-30-17)
07 Honda Accord V6 130k Silver
07 Honda Accord L4 130k Bronze
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I think the handle will be separate from the window switch. I do not remember doing anything to my 2001 V70 handle when I tried to replace my window switch. The window switch seems to be electronically mated to the drive side and a used replacement did not work for me.Or maybe I got a used base model switch and it did not work for my T5.
See my earlier post viewtopic.php?t=105053
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
There is a screw underneath the switch for removing/installing a new handle. There are 6 plastic tabs and a T25 screw (already removed in your picture) holding the module to the door panel. I use a small and long screwdriver to release the three plastic tabs between the module and the door panel first, then release the three that are on the outside of the module.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
volbul2
Has thanked: 1 time
Post by volbul2 »
Thank you for the responses. After studying the assembly I figured out how to remove the switch. Carefully pry the 3 tabs and ease the switch out. Sneaked a thin table knife to push the other 3 tabs on the other side of the switch.
And yes, the switches have to be swapped. The 07 switch will not work on the 04. I probably could have just replaced the handle but the plastic on driver's side latch broke a few months ago so I decided to get the whole assembly for the passenger side in case the same thing happens. I could tell the plastics on the 07 where sturdier than the 04.
Has thanked: 2203 times
Been thanked: 1852 times
I think I documented that there seems to be 3 variants of the driver's DDM. 01-03, 04, 05-
I have now learned from this the passenger side window controller may be linked/programmed to the master DDM. I honestly think it is more likely the year version may be the critical issue more than it is programmed to the DDM.
