P2 01-07 Seatbelt latching clean re-tension unlocking neck cuts
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
Rear seatbelts loose their retractable-ness and get jammed in the doors. Removal of the reel which is located inside the seatback. Removing the plastic covers slide trim (A) inwards or it lifts upward then the cover slides outward, it may also stick to the leather in places.
Incase like me you accidently latch the seatback trying to un-reel the seatbelt, you need to push (B) lever while lifting the plastic cover.
**BEST** to avoid latching the seatback while the cover is partially removed by removing the seat belt anchor bolt.
Seatbelt is hidden (C) inside cushion its a 15mm nut, all other bolts are 14mm
Removal of rear seatbelt cover
Very hard to remove trim inserts (pull them up) there must be a trick to releasing them?
trim insert
trim insert
Pin (A) that seatback slides into
removing seatback
removing seatback
Its not necessary to remove from car but just saves your back.
BEWARE of this fake join, the whole piece slides in (A) direction, the plastic around the head rest is brittle and breaks easy.
Fake joint
Fake joint
With the reel out you tension the spring (pictured other side) and or by removing the pins the angle lock can be serviced. The angle locks when the seatback or car is not level. There is also a friction lock that locks when belt pulled too fast.
My hope is that cleaning can de- stiffen the belts and help resolve retracting issue
Angle lock
Angle lock
Angle lock reel.jpg (121.88 KiB) Viewed 472 times
darylrobert
Anyone else have the belt riding up to the neck? First i thought it was my seat position but never had this issue with previous Volvo's or numerous rental cars. Bought this metal clip but it render's the retraction INOP so thats no good.
seatbelt clip
seatbelt clip
metal clip.jpg (2.18 KiB) Viewed 445 times
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
My rear seatbelts are also "lazy" and need assistance retracting. Curious if this works, and why not just using say a toothbrush with some warm soapy water wouldn't be sufficient?
04s60 2.4
04xc70 2.5t
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
darylrobert wrote: 27 Dec 2025, 06:18 Rear seatbelts loose their retractable-ness and get jammed in the doors. Removal of the reel which is located inside the seatback. Removing the plastic covers slide trim (A) inwards or it lifts upward then the cover slides outward, it may also stick to the leather in places.
Please identify your year and model. This looks like P2, but I am not sure.
darylrobert
br0dy519 wrote: 29 Dec 2025, 07:47 My rear seatbelts are also "lazy" and need assistance retracting. Curious if this works, and why not just using say a toothbrush with some warm soapy water wouldn't be sufficient?
Try the easiest option first, removal of the rear seatbelts is a real pain and taking them apart is tricky. Getting replacement belts from the junkyard is a much smarter option
br0dy519
Post by br0dy519 »
I had an issue with the 3rd row seatbelt installation on my XC where I let them extend beyond their limit and then had to manually retract them. I prefer to keep my sanity than ever have to mess about such a thing again...
04s60 2.4
04xc70 2.5t
darylrobert
Yes, alot of patience is required, i would describe working on the rear seat backrest as like solving a "rubiks cube" trying to solve multiple puzzles at once using alot of Swedish swear words.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
darylrobert wrote: 29 Dec 2025, 20:38
Don't buy seatbelts out of a car with big front end damage! There is a good chance that the explosive pre-tensioners have already fired and the webbing may be stretched.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
