95 850: abnormal no-key chime
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I remember my 98 models would chime with the door open if the key was in the ignition, not on. But my 95 chimes with the door open without a key.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
It’s just happy that it doesn’t have OBD
A bit of lube in the key cylinder? Terminal S in the key triggers the chime
- CIK7
So do I put lube on the key and just jam it in and out a few times? Or do I just use one of those needleless syringes to inject lube? I assume terminal S is controlled by one of the pins? That's what it sounds like.abscate wrote: 01 Jan 2026, 18:37 It’s just happy that it doesn’t have OBD
CIK7 wrote: 01 Jan 2026, 21:22So do I put lube on the key and just jam it in and out a few times? Or do I just use one of those needleless syringes to inject lube? I assume terminal S is controlled by one of the pins? That's what it sounds like.abscate wrote: 01 Jan 2026, 18:37 It’s just happy that it doesn’t have OBD
Lube key, insert.
I think the chime gets activated early in key insertion, ie you have to pull the key all the way out to stop
- CIK7
This did not fix the issue.abscate wrote: 02 Jan 2026, 05:24CIK7 wrote: 01 Jan 2026, 21:22So do I put lube on the key and just jam it in and out a few times? Or do I just use one of those needleless syringes to inject lube? I assume terminal S is controlled by one of the pins? That's what it sounds like.abscate wrote: 01 Jan 2026, 18:37 It’s just happy that it doesn’t have OBD
Lube key, insert.
I played with my key last night. The minute the key touches the plate in the lock the chime starts.I’ll guess your lock cylinder is grounded somehow from old age.
“When the chimes stop. Pick up your gun. Colonel.,just try”
- CIK7
Updateabscate wrote: 03 Jan 2026, 03:41 I played with my key last night. The minute the key touches the plate in the lock the chime starts.I’ll guess your lock cylinder is grounded somehow from old age.
If I drive at a side angle (ex. a hill), the open-door key-in chime will randomly start. Im not worried about fixing it though. Neighbor badly wants to buy it. Its safe to drive and and all that.
- 12 Replies
- 3342 Views
- 966 Views
Last post by S40VolVo01NC
- 980 Views
Last post by Boosted40
- 11 Replies
- 2723 Views
Last post by Free2drive!
- 573 Views
Last post by RickHaleParker
