2011 XC60 Misfire on #4
xyourobob
- Year and Model: 2004 XC90, 2011 XC60
- Been thanked: 4 times
The XC60 T6 3.0 started misfiring, OBD2 said cylinders 2 & 4. I just replaced the plugs in July, I swapped the coils for those cylinders with their neighbors, and #4 was still missing. I did a compression check and all cylinders read close to 150psi with the exception of #4 which is reading less than 90psi. The engine has always consumed a lot of oil, I'm wondering what my options are at this junction, the vehicle has 180K miles on her but is in pretty good shape.
xyourobob
I put a couple of caps of oil into the #cylinder and rechecked the compression and there wasn't much of a change, would that suggest that the problem is with the exhaust valve?
- Has thanked: 987 times
- Been thanked: 1075 times
Try to get a scope in cylinder 4 to check for burned valve and cylinder wear.
- 9577 Views
Last post by defense49
- 11933 Views
Last post by Cadelane1
- 1415 Views
Last post by JerryG1970
- 1145 Views
Last post by MattyShmatty
- 1338 Views
Last post by dave3134xx
