ETM test results good or bad?
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
I can feel a very slight hesitation at around 2K RPM most noticeable at lower speeds. Completed the ETM test as well as gas pedal test and noticed gas pedal glitching (freezing) randomly around the 20% throttle area . I previously upgraded from brush to contactless, maybe a cleaning will fix??
ETM test
ETM test
gas pedal glitching
gas pedal glitching
gas pedal glitching
Has thanked: 1610 times
Been thanked: 4065 times
I’ve got exactly the same issue with Karla (99 S0 awd) at 2000 rpm. I can push through it to 2750 rpm neither smooths out
We get very few electronic accelerator pedal failures here, I would guess it’s the ETM that’s unhappy.
Mine is original white label but only has 99k on it
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
Definitely clean the throttle body. The interesting thing about the second chart is that the throttle plate was hung up both when the throttle was opening and when closing but at two different angle positions. Clean close to the shaft where there is potential for hangups at throttle angles other than fully open or fully closed.
I would try re-running the ETM test with the engine hot if it wasn't already hot for the tests you posted. I would also run the ETM test a bunch of times in a row. The same open/close sweep that you are doing with your foot is happening in the ETM test. One process shouldn't be different from the other unless a different opening/closing speed is causing the fault.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
darylrobert
Tool the gas pedal apart but it was pretty clean. Part numbers are interesting on these apparently same part number has different mountings, Looks the the design changed in 2009 does the pedal pivot or is it fixed?? ..
gas pedal service
gas pedal service
pivoting pedal 2009
pivoting pedal 2009
xc90 gas pedal.jpg (34.93 KiB) Viewed 180 times
