Bad bulb indicator on when braking.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
96 855 the bad bulb indicator comes on when i touch the brake pedal but all bulbs appear to be intact/working. Possibly volt/watt problem with one of them? I switched a few around still happens though. External appearance suggests all bulbs are equally bright. More annoying than a functional problem, of course!
Has thanked: 2207 times
Been thanked: 1852 times
Is the high level brake light working? Can't recall on the 850 if there are any dual bulbs. It could be one is going bad and throwing when the brake is being used.
The systems can sometimes not like some brands of bulbs. I know my local dealer service manager (and master tech) says they regularly get issues that are down to bulb quality in aftermarket replacements. Changing the bulb usually fixes the issue.
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
When that happened to me, it was the 3rd brake light. It was intermittent.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Yes, I too, would go with the third brake light. Bulb maybe fine but contacts a little crusty. Same issue awhile back.
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
So, I had an almost bad bulb on the rear with that light coming on. I replaced it. It went off. Then I decided to replace all the brake lights and reverse lights with LEDs and that light came back on. What's tripping it is the lack of power being drawn. Those light bulbs are supposed to draw, I think, 55 watts or 25 watts, something like that. LED bulbs only draw maybe five watts I thithink.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Jotunn77
Year and Model: 97 855t - 91 945t
Has thanked: 6 times
Been thanked: 4 times
Post by Jotunn77 »
I had to replace the brake light switch when I had this problem. I was chasing the issue at the rear end of the car like yourself, switch bulbs and checking wiring with no solution. Ended up being a simple switch under the brake pedal. FCP and IPD have them.
1997 855 T5 - 297k
1991 945T - 121k
