Coil Connectors bare wires 2007 XC70 Topic is solved
8pack
Year and Model: 2007 XC70
Has thanked: 3 times
Been thanked: 2 times
Post by 8pack »
All of the connectors for my coil packs the wire has become brittle and is exposed at the connector. See picture.
Can I use something like plastic dip and some electrical tape to seal it up?
If not suggestions? Thanks!
Has thanked: 2200 times
Been thanked: 1852 times
It is certainly worth a try. I would try cleaning with electrical cleaner and gently cleaning with a toothbrush or similar, then try the liquid plastic electrical repair.
You can then re-wrap the ends of the connectors.
I believe you can buy replacements that come with flying leads to replace the tired connectors. That may be worth a try. I suggest cutting the wires at different lengths so connections are staggered. That way you can use similar sized wiring covering as currently used.
Good Luck!
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Black tape is fine.
Best is to visit a junk yard or eBay and get the whole wiring loom.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
Go to junk yard. Soldering these wires can be tricky due to copper corrosion (copper needs to be shiny), might need to cut further away from ends than expected. Clean wires with razor blade before soldering use flux and heat shrink. Recommend NOT using Volvo covering. let coils breath.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
vtl wrote: 12 Jan 2026, 18:44 Replace the harness: https://www.prancingmoose.com/volvoharn ... oilharness
Dave Barton rides again!
I got a full engine harness from Dave for my 1983 245 many years ago.
XC70Rider
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
I got a used harness from Eries Volvo several years ago. It was in great shape compared to the one on my P2. www.erievovo.com
After cleaning up the bare wires I used flux, solder and heat shrink crimps on the harness. I purchase 5 new Volvo IGN coils ands warrantied Volvo spark plugs from FCPEURO. My P2 has 197k miles but she idles and drives as if brand new.
IGN Harness from ERIE Volvo.jpg (52.02 KiB) Viewed 399 times
