I've screwed something up - 1993 240 door handle
newmex999
Year and Model: 240DL 1985
Post by newmex999 »
1993 240-Removed driver's side door handle today because I had to adjust the little barrel shaped thing which sits in the back side of the handle that screws onto the rod which opens the door. The handle was almost not opening the door, had to pick it way up with both hands. When I was in there noticed the 3 wires coming out of the bottom of the electric lock were missing insulation, so I patched them up
When I reassembled everything, door now opens fine. However, the driver side door lock will NOT go down either manually or with the key. If I manually rotate the driver door latch 2 clicks(simulating the door being closed and latched), then the lock works. Also if I disconnect the little rod coming out of the bottom of the lock plunger assembly, then the lock can be depressed.
Hard to see the assembly in the door to find out what's wrong.
