99 v70 front subframe bushing replacement
pfmet
Year and Model: V70 1999
Has thanked: 45 times
Been thanked: 22 times
Post by pfmet »
Having a difficult time locating a tutorial/ video on this project. After refurbished the struts, put new tire on and found the tie rods needed replacing. Naturally when pulling the boots back to remove inners discovered fluid within leading to rack replacement. While at it the control arms were determined to be in need of replacement as bushings were busted loose. And while we’re at it the engine mounts are a little spongy so there’s that. All the parts but one have arrived before the storm runs over us, and now I’m thinking we basically have everything going to be disconnected from the subframe at some point and wouldn’t in make sense to do those bushings now. Just OE ,factory quality, no polyurethane, with I guess new bolts. The old ones came out fine and I see they should not be reused. Can anyone steer me to some good write ups on this aspect of the project. At 206k this refresh will take the car well into the next owners tenure I would think which is my goal at this point.
Happy and Healthy New Year to all and thanks as always. Peter
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
pfmet wrote: 24 Jan 2026, 16:34 Having a difficult time locating a tutorial/ video on this project. After refurbished the struts, put new tire on and found the tie rods needed replacing. Naturally when pulling the boots back to remove inners discovered fluid within leading to rack replacement. While at it the control arms were determined to be in need of replacement as bushings were busted loose. And while we’re at it the engine mounts are a little spongy so there’s that. All the parts but one have arrived before the storm runs over us, and now I’m thinking we basically have everything going to be disconnected from the subframe at some point and wouldn’t in make sense to do those bushings now. Just OE ,factory quality, no polyurethane, with I guess new bolts. The old ones came out fine and I see they should not be reused. Can anyone steer me to some good write ups on this aspect of the project. At 206k this refresh will take the car well into the next owners tenure I would think which is my goal at this point.
The stock subframe bushings are surrounded by a plastic sleeve. You have to break that sleeve to get them out. Some people have been luck and can just hammer the bushings out. I have to use a flat blade screw drive as a chisel and hammer it through the plastic sleeve. After that they hammered out easily. When reinstalling I used the sub frame bolt to pull them in. Apply plenty of grease.
Here are some video references.
pfmet
Post by pfmet »
Thanks for the reply Zion. I’ve admired Scarlet for a while now and note you’ve done a lot of work on her. Your photo is what I’ve pictured in my future with the subframe. I’ll let you know how it goes. Need a recommendation on an SMI steering rack replacement as well actually. Going to start another thread I guess to hopefully arouse more interest. I’d be thankful for your thoughts.
ZionXIX
Post by ZionXIX »
Part of that subframe job was replacing the steering rack. I purchased the cheapest "new" rack on rock auto. I haven't put a lot of miles on it yet but it works. Biggest problem I found was moving the captive bolts from the old rack to the new one. They look like small wheel hub bolts that are press fit eith splints. I ended up cracking the housing for one of the bolts during installation. I just finished the installation regardless and hasn't given me any problems so far.
Has thanked: 1610 times
Been thanked: 4065 times
Definitely put 30 seconds of heat on those rack nuts bolts , bring careful with the flame, before zipping off.
New nuts are cheap, too, right from Volvo and FCP.
My Indy loves working on my cars since he notes I always replace hardware
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Here's a link that shows a simple press I made with some regular bar stock.
viewtopic.php?p=481643&hilit=subframe#p481643
pfmet
Post by pfmet »
Been distracted by failing snow removal equipment. Stupid little stuff but it all takes time and causes unnecessary stress especially with the future possibilities.
So thank you again Zion and abscate. And amblerman, I was considering a homemade press of the sort you describe, perhaps with a pipe nipple spacer, or I’d bet schedule 40 PVC would take that pressure. I’ll report on details .
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
If you have access to a 3D printer or know someone with a 3D printer, you can also use my 3D printed subframe bushing tool: viewtopic.php?p=641202#p641202
It helped me and others a lot getting the bushings in without distorting or destroying the bushings.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
crasbe wrote: 28 Jan 2026, 04:21 If you have access to a 3D printer or know someone with a 3D printer, you can also use my 3D printed subframe bushing tool: viewtopic.php?p=641202#p641202
I'd buy one if it was available. (note to printers lurking out there)
1999 V70 GLT
crasbe
Post by crasbe »
Unfortunately due to US import restrictions, I couldn't legally sell it to anyone in the US (only gifts up to 100$ are allowed) and shipping costs 2-4x more than the material. I don't want to become political, but I do hope matters in your country will be in order again soon :/
But there are plenty of people with 3D printers in the US who can print it for you.
