a bit misleading. but as these cars get older and parts are harder to find and i needed a vvt solenoid gasket (yes, i know theyre still currently available) i was curious if one could easily cut complex shapes out themselves from gasket sheet at home using a cricut (or silhouette or whatever brand your wife/gf might have) cutter.
the answer is, yes, quite easily
also, i know this needs a piece of wire cloth over the one hole, i just dont have the right size mesh at the moment
Hard to find Gaskets
- Been thanked: 4071 times
Very neat! This is good to know fir the 1999 2000 model year only gaskets for intake and exhaust
30731212
Still available now, good stocking stuffers to hit $50 free shipping at FCP
30731212
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 33 times
- Been thanked: 82 times
If there is a gasket available or a flat surface, I usually put it on a flat bed scanner and put Millimeter paper behind it. Then it's easy to scale and recreate in CAD and you can cut it out with a laser cutter or at least have an easy template to work with:
This is a screenshot of what the scan looks like and the reconstructed part: And this is the result:
https://www.printables.com/model/145326 ... 6170520280
Many hackerspaces or makerspaces have laser cutters available and some paper gasket material is laser safe.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
- Has thanked: 987 times
- Been thanked: 1076 times
I have cut quite a few gaskets. For holes buy a hole punch kit from Harbor Freight. Use hardwood backing when punching the holes. A box cutter with sharp blade can do the larger profiles. Work slow and careful.
If you have a case iron mating surface with a sharp edge, you can sometimes cut the gasket using a ball peen hammer tapping around the edges.
Bulk Gasket material is available from auto parts stores. You are out of luck if you have a metal reinforced gasket.
lrock
- Year and Model: 2001 v70 xc
- Has thanked: 9 times
- Been thanked: 37 times
i cut the one above on a cricut, it's basicly a 2 axis cnc cutter, the one i had access to has a 24" X axis and an infinite Y axis, it cut the vvt gasket (rubber/paper type gasket .7mm thick) in 4 passes, probably could have done it in 3, but the amount of time difference would be negligible. if i needed a metal reinforced one i would likely get a fiber or diode laser head for one of my 3d printers and use that instead.volvolugnut wrote: 30 Jan 2026, 09:28 I have cut quite a few gaskets. For holes buy a hole punch kit from Harbor Freight. Use hardwood backing when punching the holes. A box cutter with sharp blade can do the larger profiles. Work slow and careful.
manually is fine, but i'd really rather not if i don't have to.
lrock
the cricut ended up working good for me.crasbe wrote: 30 Jan 2026, 08:04 If there is a gasket available or a flat surface, I usually put it on a flat bed scanner and put Millimeter paper behind it. Then it's easy to scale and recreate in CAD and you can cut it out with a laser cutter or at least have an easy template to work with:
also, thanks for the cam seal drifts, i printed them out 2 weeks ago when i replaced all my seals. they worked great!
- 696 Views
- 11 Replies
- 3260 Views
- 492 Views
Last post by darrylrobert
- 13 Replies
- 700 Views
Last post by RedBrickCollector
- 985 Views
Last post by 93Regina
