Vacuum tree wiggle- 98 S70 T5
veezmachine
Year and Model: 1998 S70 T5
Has thanked: 2 times
Been thanked: 2 times
Post by veezmachine »
Hey all, was wondering if anyone else noticed that the vacuum tree on the manifold has a bit of wiggle/play to it even when tightened down? Asking because I've snapped 2 bolts before trying to get it tight on there (and managed to get them both out thankfully), but I wanted to make sure that I was in the right area by leaving it after just hand-tightening. I can't find any torque specs for it, so I wanted to double chekc. Thanks!
Has thanked: 1609 times
Been thanked: 4064 times
veezmachine wrote: 31 Jan 2026, 14:23 Hey all, was wondering if anyone else noticed that the vacuum tree on the manifold has a bit of wiggle/play to it even when tightened down? Asking because I've snapped 2 bolts before trying to get it tight on there (and managed to get them both out thankfully), but I wanted to make sure that I was in the right area by leaving it after just hand-tightening. I can't find any torque specs for it, so I wanted to double chekc. Thanks!
That needs to be firm to seal against vacuum leaks. Check the gasket and see if there is nastiness there
Just a wrist torque on those bolts, don’t gorilla them. M6 so 10 ft lb is plenty
Has thanked: 2197 times
Been thanked: 1850 times
Been a long time since I removed a vacuum tree. Does it not have an O-ring on there where it bolts down? If it does, it does not have to be cranked all the way down hard. Are the bolts too long so bottoming out before getting the tree tight?
