1999 Volvo V70 Transmission hard reverse shift
DimBor22
Year and Model: 1977 V70 Vagon
Post by DimBor22 »
Hello Forum, I have a problem in Cold wheathe Whith 99 Volvo V70, In mornig, cold wheather I start the Engine I wait to warm up. When I put it in reverse, hard noise in the transmission. I just change Trasmitio fluid do not help me with nothig I have the same problem.
Somebody knows what the Problem I will appreciate your help.
Dimitry
Has thanked: 2199 times
Been thanked: 1852 times
Is the car turbo or non-turbo (NA)?
How cold is cold where you are? Cold up her is -40C/F
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
DimBor22 wrote: 09 Feb 2026, 20:14 Hello Forum, I have a problem in Cold wheathe Whith 99 Volvo V70, In mornig, cold wheather I start the Engine I wait to warm up. When I put it in reverse, hard noise in the transmission. I just change Trasmitio fluid do not help me with nothig I have the same problem.
Dimitry
Palo Alto CA / South Bay is not really considered cold. When you say hard noise you mean it shifts hard into gear? Check for proper fluid level again.
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
DImBor22,
There are a few possibilities.
1) As stated above make sure your fluid level is correct. Check the level when the engine has reached operating temperature
2) worn transmission or engine mounts. When placing the car in reverse, if either mounts are worn or bad there will be noticeable clunk. This is due to excessive drivetrain movement or gear stress when switching directions. if the noise only occurs when shifting into reverse, this is a definitely a possibility. Look for cracked mounts, dry rot or separation at mounting points.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
DimBor22
Post by DimBor22 »
Thanks < Grantkat > appreciate your suggestion I will check I will replace the engine mount I have 200 050 mile.
Dimitry
