We have a sound coming from the engine. Most notable when the engine is at operating temp. Looks like it’s coming from the back of the engine, but not 100% positive.
I have removed the auxiliary belt and timing belt cover and inspected for wear marks, not the case.
Car drives fine, burns 0.5 quarts between 5k oil changes.
I have attached a sound clip with the noise. It’s a low frequency sound, like something is rubbing.
Please let me know if you recognize this sound.
2006 XC70 246k Engine noise
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
- Engine sound .m4a
- (106.45 KiB) Downloaded 15 times
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Was this audio clip recorded with serpentine belt reinstalled? (This way you would eliminate lots of moving parts). If yes, I would ask how long ago you changed your timming belt/ water pump components and if they were of a decent quality. If the noise was recorded with serpentine belt- have you checked your power steering pump fluid level?
Good luck
Good luck
- Has thanked: 2205 times
Check the exhaust manifold nuts are tight. These engine like to have them come loose, and then blow the manifold gasket.
Rvolvos
Thanks much for your reply.Vova585 wrote: 16 Feb 2026, 20:49 Was this audio clip recorded with serpentine belt reinstalled? (This way you would eliminate lots of moving parts). If yes, I would ask how long ago you changed your timming belt/ water pump components and if they were of a decent quality. If the noise was recorded with serpentine belt- have you checked your power steering pump fluid level?
Good luck
The clip was recorded with the serpentine belt on.
Timing belt, waterpump pulleys and tensioner with the kit from FCP. Continental belt , Aisin waterpump @ 194k miles in 2021
Just checked the power steering fluid, level is okay.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
Rvolvos
Thanks much for your reply.vtl wrote: 17 Feb 2026, 13:10 Whoosh-whoosh-whoosh is likely a VVT hub. Exhaust side usually dies first.
I did replace both VVT hubs with new ones from Volvo, together with the timing belt at 194k miles.
I will try to listen with a stethoscope, near the hubs.
Now I wished that I purchased them from FCP
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
Rvolvos
Thanks much for your reply.scot850 wrote: 17 Feb 2026, 08:35 Check the exhaust manifold nuts are tight. These engine like to have them come loose, and then blow the manifold gasket.
I will try to tighten them.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
That's not enough time/miles to have them killed.Rvolvos wrote: 17 Feb 2026, 19:00 I did replace both VVT hubs with new ones from Volvo, together with the timing belt at 194k miles.
Now I wished that I purchased them from FCP![]()
Can you remove the top plastic cover and shoot a video of t-belt with engine running?
Rvolvos
Yes , I will report back this weekend.vtl wrote: 18 Feb 2026, 08:24That's not enough time/miles to have them killed.Rvolvos wrote: 17 Feb 2026, 19:00 I did replace both VVT hubs with new ones from Volvo, together with the timing belt at 194k miles.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
- 208 Views
Last post by Blacklab467
- 2449 Views
Last post by Ou2mame
- 1030 Views
Last post by jonesg
- 834 Views
Last post by VFLXC90
- 5420 Views
