Placeholder for my Volvo job today before the bomb cyclone
I used the Febi part fromFCP
Official Volvo part name backup light switch
Symptom, no reverse light, bulb check good, no power to lamp housing
1999 v70 t5 m6 reverse light switch 30713679
- Been thanked: 4071 times
Picture bank!
Disconnect the negative terminal , more on this later.
The switch is under the air cleaner, so you have to get thst out of the way. Undo the band clamp on the snorkel. I find it’s much easier to Pop the cleaner out of the snorkel by breaking it down into the top half and bottom, like replacing the air filter
If you label your parts with the FCP order number it makes return bookkeeping a snap!
The connector is a squeeze and lift, two pin connector. Hot on one side , normally open. Engaging reverse gear closes the switch
You need a deep 22 mm socket to get the switch loose, my big boys were thick and only picked up half of the flats on the switch. A cheap thinner walled socket would be better.
Tighten it to the stop, non critical torque , maybe 5-10 Nm
Confession - I didn’t disconnect the neg, figuring I was working away from the battery. Swung the breaker , hit the pos terminal and welded a nice divot out of it with the discharge. Good practices should be followed, not optional . Imagine if that bar had welded it self to the positive? Ugh.
22mm deep socket needed for this removal. Non critical torque, just snug it up
- 1411 Views
- 2618 Views
Last post by styang19
- 13 Replies
- 2980 Views
Last post by polskamafia mjl
- 542 Views
Last post by primitive_man
- 15 Replies
- 1698 Views
Last post by manovlov
