96 850 remote key fob door locks SUPER annoying
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Is there a switch or contact, in the car, that failure would intermittently prevent key fob use? My FOB works 95% of the time, but seemingly every time I stop to get gas, I can't operate the locks with the FOB. I don't think this is the typical low battery, or dirty contacts in the FOB itself. I took care of that a few months ago. However, it's like the car stops listening for the radio signal from the FOB, as no amount of button pressing will get the car to respond. The next drive cycle it's fine, as if nothing was wrong.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 2211 times
Been thanked: 1852 times
That is a strange issue. I have had issues with P80 fobs being intermittent with age (fob not me!). The transmit ships reduce range over time and sometimes depending where you are around the car can make a difference to fob performance.
Does the fob work normally if when you have this issue you lock and unlock the car manually with the key and then re-try the fob?
454cid
Post by 454cid »
scot850 wrote: 22 Feb 2026, 16:32 That is a strange issue. I have had issues with P80 fobs being intermittent with age (fob not me!). The transmit ships reduce range over time and sometimes depending where you are around the car can make a difference to fob performance.
Usually I'm right at the driver's side front, or by the fuel filler
I've tried that and today tried actually restarting the car and neither worked immediately. By the time I was ready to go, I was able to use the FOB.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Do you have more than one working fob, and if so, do you have the same issue with both? Trying to see if the issue is the fob or the system.
454cid
Post by 454cid »
scot850 wrote: 22 Feb 2026, 23:28 Do you have more than one working fob, and if so, do you have the same issue with both? Trying to see if the issue is the fob or the system.
Unfortunately, the other key, and fob disappeared on me over the last year. I kept thinking, I'd run across it, but it hasn't turned up, so I'm thinking it's permanently lost.
I probably should try to get another, and get a new key cut.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
It is therefore hard to figure out if the issue is a faulty fob with say a sticking button, or if it is the system itself that is the issue.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I had to replace a fob recently because it was intermittent... I took the old one apart later and found lots of corrosion inside the two dome contacts and on the carbon traces inside the switches.
454cid
Post by 454cid »
jreed wrote: 24 Feb 2026, 05:38 I had to replace a fob recently because it was intermittent... I took the old one apart later and found lots of corrosion inside the two dome contacts and on the carbon traces inside the switches.
When I took the fob apart I didn't find any corrosion and I thoroughly cleaned it with alcohol and then tested the battery. Upon reassembly it worked much better. I don't believe this problem of it randomly being completely irresponsive is on the fob side of things.
My thought would be that if it was the fob, repeated pushes would eventually get a result, but that's not the case. It won't work at all until the next drive cycle.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
jreed
Post by jreed »
Sometimes when one of our fobs doesn't get the car to respond, I hold the end of the fob up to my chin and then press the button... that seems to make the fob transmit a stronger signal and the car responds. You could try that when your car isn't responding and see if that helps.
And yes, it is a thing!
