Timing Chain or VVT noise
ikeever
Year and Model: 2011
Post by ikeever »
285K mile 3.2L 2011 XC90.
I'm getting some slight rattle noise in the timing assembly. It's not READ.
I'm doing a complete timing chain, guide, tensioner, ect rebuild.
My question to the group: FCP rebuild kit doesn't mention replacing both cam VVT gears. Does anyone have any experience with how to check these gears or if they wear out? It's a well-maintained engine, single owner. I'm struggling spending $500 on the gears alone for an engine with almost 300k miles... always leery about eBay used stuff cause it could have a half million miles on a "good used part" too. Let me know if anyone has already been here. Thanks
Has thanked: 1609 times
Been thanked: 4063 times
I replaced an exhaust VVT on my T5 at about 150k miles, maybe 175k miles? At 300k , they are certainly well unto their lifespan.
Use a piece of hose to isolate the noise to the hub with the timing cover off to confirm the diagnosis. I would only replace the noisy one, not a quiet one unless you are racking up 30k miles per year
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
abscate wrote: 24 Feb 2026, 03:32 I replaced an exhaust VVT on my T5 at about 150k miles, maybe 175k miles? At 300k , they are certainly well unto their lifespan.
2013A XC90 with 170,900 miles.
Lol!
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Motor is shared with the Land Rover and a couple of other vehicles. Might be wise to expand your search to cover those models. Maybe check the LR site and see if there's any information there- https://www.freel2.com/forum/topic32504.html for a representative post.
seandodwell63
Year and Model: 2007 XC90
Post by seandodwell63 »
Yes i can confirm LR parts for same engine much cheaper on the whole. Getting the LR part no is tricky but I use
https://www.advancedfactors.co.uk/32-ti ... rs-11988-c
to find the part no. then
https://britcar.com/process.php?xOid=38 ... 1765830729
to buy them although not all engine parts are shown on the AF web page
Hoep this helps, and if anyone know where to get oversize pistons for a re-bore on a 3.2 SI6 engine please let me know, cheaper ones that is, not LR or Volvo prices !!! I'm planning a full re-build on an old engine I have head is done just need to sort the block!
ikeever
Post by ikeever »
New chain, tensioner, guides, and vvt sprockets…. Noise still there, at idle sounds like a jar of marbles clanking somewhere…. Search continues
ikeever
Post by ikeever »
ikeever
Post by ikeever »
I think the noise is coming from the water pump. I’m gunna remove belt and start the engine to isolate.
