no start after changing timing belt
OntheDL
- Year and Model: 1985 240dl
- Has thanked: 3 times
I have a 1985 240dl that timing belt had slipped off due to a worn tensioner. After replacing the belt and tensioner the car would not start, it turns over but does not catch. There is spark at the plugs, smells like there is gas when i open the cylinder, the cam is spinning as well as the belts, there is voltage at the 25 amp fuse, ignition coil. Would the belts still spin if it was a sheared cam dowel pin?
- 23 Replies
- 18259 Views
Last post by jonesg
- 2650 Views
Last post by mf70
- 10060 Views
Last post by SuperHerman
- 2202 Views
Last post by volvolugnut
- 5509 Views
Last post by jimmy57
