1999 S70 GLT.
I noticed this morning that my HVAC fan was not blowing all that great this am and I heard a noise I do not recall hearing before.
At lunch today I went out and tried it and here is what I have:
When moving the slide switch from 0 to full blast, the fan initially comes on and blows like it should, however soon after that (maybe 20 seconds) the fan starts to slow down and it makes a weird noise that i would have trouble describing. The noise is subtle but not what I would expect to hear.
normally this is behavior one would expect in an electric fan motor which is failing. However, i want to make sure it is not a bad or failing resistor. My experience has been a failing resistor either blows full blast no matter what or it does nothing.
thoughts?
Question on Blower/Resistor
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
If you have the slide fan control, you have ECC and a power transistor pack, not a resistor pack. These can fail in part, unlike the resistor pack which usually fails open and leaves you with high speed or none.
But , Irish betting puts 15:1 odds of blower motor over transistor pack on these cars based on history here.
Okay, I made up that last bit, but I would lean that way
About $100 for the TYC replacement with the FCP warranty
- Grantkat
awesome - so can the fan be bench tested once removed? i.e. can I connect my 12vdc power supply to it to test the motor?
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
Chieber
- Year and Model: 1998 v70
- Has thanked: 69 times
- Been thanked: 49 times
Spin the motor and you’ll feel that it doesn’t smoothly turn around anymore.
Mine went out like a squealing pig. When I took the fan out, it wouldn’t spin freely anymore. There was a lot of resistance trying to turn the blades round.
1/2 a shitbox V70 1998 2.5 NA
- Has thanked: 2199 times
The orientation you have the motor when testing it should be the same as when fitted in the car. The bearing wear and the fand can move forward and backward which can jam it from turning. Sometimes all the bearings need is a little light oil lube to get it moving well again. If that does not work, then it is a new/used motor.
Can be bench tested.
Looks like only the FEBI brand is left. It’s a 1998,1999,2000 only part since we are special
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Just be ready for that blower to jump across the bench when you put power to it.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- Grantkat
Great guys! I will see what i find, planning to pull it tonight. Abscate I saw that as well. Backorder is a bad word in my dictionary...Assuming the motor is bad Febi it is....
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
…or ignore Erikv posting there is a two word solution..
It’s junkyard, not junk yard
The problem with the S/V70 platform in junkyards is you can read the mileage on the ODO without battery power, and it would be good to get a blower from a 100k car rather than a 200k car. I guess a wreck would be a decent bet
- Grantkat
OK guys - the blower motor failed the bench test - but here's a big FYI
I initially hooked it up backwards - reverse of how its connected inside the vehicle. Put 12V to it and it ran flawlessly in half a dozen starts and stops including 3+ minutes with no indication of issue. Then I reversed the leads, realizing I had it backwards and Viola it ran for about 10 seconds and then slowed down more as time when on. Additionally it failed to start in 3 attempts to the point where I had to budge the cage and then it started turning. So.... bad blower motor.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
