Antenna ring bulb spec? - 2006 S60 AWD Topic is solved
Has thanked: 2200 times
Been thanked: 1852 times
The bulb is out on this car's antenna ring. The bulb and holder look like a Neo type LED bulb. I refuse to pay over $25 CDN for a replacement. However, I used to buy replacement bulbs from Mouser and Digi-key and replace then in the existing bulb holders on my P80's. However, I can not find the spec for these bulbs, particularly the operating Voltage. Anyone know? are they 12-14V or 5V?
The bulb dimension is approx. 5mm diameter and 8-9mm tall with the lower shoulder included. 2 flying leads coming out from the bottom of the bulb.
Thanks,
Looks like it a T3 T4.2 with a 12V rating. I ordered 20 off Ali Express for $10 CDN.
https://www.aliexpress.com/item/1005006 ... in_prod%3A
