Looking to get back to working on the 99 field rescue. I got everything together but the transmission no worky and I really don't want to put a slush box back in it if I am going to go through the trouble of replacing it.
I have a full swap kit here for it, all the parts and components to do it but the hang up is tuning it for the manual conversion. I have hit a roadblock with finding anyone who can do the necessary alterations to the ecu for the conversion from auto to manual. 98 back no problem, 2000+ no problem, 99 is a bastard stepchild apparently.
Can anyone pointe in the right direction? Anyone out there tuning the 99 ECU's? can you just leave the auto selector in there set in neutral? Not well versed on these so sorry for the stupid questions. TIA
Help with tuning/manual swap 1999 V70R
reach out to Bdub (Ill ping him) here who has done a 1999. I think Hilton is the guy who does the ECU change to eliminate TCU chatter and perhaps integrate the clutch switch and reverse light in too.
(reverse light might go through CDM , not ECU but those guys will know)
chaosrob
- Year and Model: 1999 v70R
- Has thanked: 37 times
- Been thanked: 15 times
I'm not familiar with who that is and I looked in the user list and couldn't find anyone matching that name
abscate wrote: 07 Mar 2026, 10:15 reach out to Bdub (Ill ping him) here who has done a 1999. I think Hilton is the guy who does the ECU change to eliminate TCU chatter and perhaps integrate the clutch switch and reverse light in too.
I texted him. Hilton did his m56 ECU tune so that’s who you want.
I’ve forgotten bdub username here, but if you search the forum for Miata you wind us exchanging barbs over my Beetle and his Miata
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
bmdubya1198
Found Hilton here
https://hiltontuning.com/product/volvo-tuning/
Rob you will need an M58 transmission to keep AWD R capability but then you will have the coveted awd manual combo that is a EU and Canada only option
On edit M66 works too, see below
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
P1 M66 AWD works also Abscate - it’s a pretty straightforward and bolt-in swap by us US folks that were deprived of availability of the good gearbox with AWD on this side of the pond.
Hilton can do the tuning, but I’d be wary using him - he’s legendary for horrific response times, questionable tunes when he does get back to you, and ghosting you when his mediocre tune blows up your car.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
If you have access to the original donor and it matched up with trans and tune then you can fully swap locks, dash module, lock assembly, ECu, and it should work if I recall from long ago.chaosrob wrote: 07 Mar 2026, 07:34 Looking to get back to working on the 99 field rescue. I got everything together but the transmission no worky and I really don't want to put a slush box back in it if I am going to go through the trouble of replacing it.
Other option is if we can crowdsource enough bin files then we could use some tools to examine the binaries and see if it could identify the maps for where the manual bits are set. This is far from what should be done, but is in the realm of what could be done if that makes sense.
2008 S60 2.5T Auto (Sold)
- 4512 Views
Last post by TheMrFailz
- 213 Views
- 1659 Views
Last post by MackN
- 1266 Views
Last post by bmdubya1198
- 441 Views
Last post by Chuck W
