Hi guys
Need an answer quick. 300km from home and getting my car from the airport after parking for a week and it’s misfiring. Sorry I know this has been asked plenty. I’m going to limp it to the auto parts store for a code read. I don’t have my reader or my 10mm or any of my 12 spare coils on me. Lesson learned.
Safe to disconnect the ignition coil for the bad cylinder and drive it home? Do i need to unplug the fuel injector as well?
Misfire - need to get home! Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Been thanked: 504 times
Actually d/c the injector is the most important thing to prevent unburned fuel going down the engine oil or in the cat.
- br0dy519
Thank you.
Ugh- p0300 0303 and 0305 (twice). I unplugged injector 5 and will hope for the best on this trip. Should I unplug the coil too or does that not matter ?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Been thanked: 4070 times
Does not matter. Can you tell which cylinder is bad? Try to only disconnect one
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Do a compression test in all cylinders when you get home.
I drove 200+ miles with a hole in exhaust valve in #1, haven't disconnected anything. When Bosch ECU correctly diagnoses which cylinder is misfiring, it cuts fuel and spark from this cylinder.
- br0dy519
I got home y’all. I started poking around my car and realized I had a 10mm and a spare coil in the spare tire well! I popped it into cylinder 5 and she didn’t buck once on the way home. Good idea to do compression test. No codes came back after cleared and driven 300km.
LESSON TO ALL: ALWAYS BRING A CODE READER ON TRIPS! And a 10mm and a coil. I got lucky and the guys at the parts store let me use their reader this morning.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
If you roll her 300km for work you should run on the PM model and give her a new set of coils.
The company owes you $180 just for that trip so that’s most of a set of Bosch coils from FCP
Don’t forget the torx bit for the pretty cover for that tool kit
Note for others....
- Around town, no worry...you can always run home to get tools or drive some miles with misfire to get home.
One bad coil...ok but 2 bad coils is almost undrivable.
- Best is new coils (Bosch) as @abscate said.
- Tools in the trunk as mentioned: Code reader, Torx key (I permanently removed the engine cosmetic cover and leave it in the trunk). NOTE: early cars 10-mm but later years ---> it is 8-mm bolts (just to save a few milligrams for fuel efficiency lol).
- 1119 Views
- 25 Replies
- 6187 Views
Last post by aaron1611
- 19 Replies
- 10270 Views
Last post by Barledge
- 2063 Views
Last post by polskamafia mjl
- 392 Views
Last post by Ozark Lee
