Car stuck in panic mode/wont start
Meatshield
- Year and Model: 1998 S70 T-5 manual
Hello so my car is a 1998 S70 T5. The other morning my doors randomly were all locked I usually never lock it and when I unlocked it, opened the door my panic alarm started going off. And won’t shut off. It doesn’t crank doesn’t start. Has anyone had this issue at all? What’s was your fix?
- Has thanked: 2203 times
Try manually locking and locking the driver's door lock with the key (don't use the fob). Then try and start it. Something has tripped your car's security system and it has immobilized the car. Locking and locking the car a few times resets it.
Give it a try.
Give it a try.
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
Immo no if America.. VGLA lock and Alarm mostly this year. VGLA has programmed or not to reset by door lock so by up to what programming it has that works or has no effect.
You can read last alarm cause, program it fully by yourself, or read live data from VGLA with android app if you want. :]
This is a thing. I have had it happen when working on a car and disconnecting and reconnecting the battery on the first attempt to start the car. Not just once but several times on 98 and on cars.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I have to do that sometimes. Usually at the gas station.scot850 wrote: 10 Mar 2026, 23:39 Try manually locking and locking the driver's door lock with the key (don't use the fob). Then try and start it. Something has tripped your car's security system and it has immobilized the car. Locking and locking the car a few times resets it.
Give it a try.
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
