95 850: cracked AC low side port Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
I thought I had run low on refrigerant. And I suppose that is accurate. I stopped at Walmart and bought a $30 can. Began to fill the low port. Then I shifted to the side and leaned over a bit for comfort. I noticed that stuff bubbling out the side of the low port. I used the scrader tool to tighten the valve. It was sort of loose. Tried again But it still leaked out. I removed the fill hose. And that stuff was bubbling out the side/neck from the first groove above the yellow o-ring. Then I noticed the low port has a slight groove at the base where it meets the main line. Is the low port removable from the main line? Do y'all have a part number?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 2200 times
Been thanked: 1852 times
I have had issues with the Schraeder valve leaking and had to replace it. I now do that anytime I need to have a P80 re-gassed.
I don't think the part is available separately based on the parts drawing and there is no separate part number:
https://www.volvocarstorontoparts.ca/p/ ... 37406.html
Has thanked: 1610 times
Been thanked: 4065 times
The low port is hard welded to that line. The valve itself is replaceable.
