95 850: opposite mpg effect with gas pedal Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Instead of getting better gas mileage by letting off the gas pedal, it actually plummets from maybe 20 or so down to 4 or 5 mpg. If I'm averaging about 20 or so with a constant pedal pressure and I suddenly stomp the gas down, the gas mileage will skyrocket to 30-40 miles per gallon. Bonkers like Yonkers.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
Just stomp that pedal then! :D
850 T5-R '95 auto Image
Has thanked: 1610 times
Been thanked: 4068 times
Somewhere buried in these pages Jimmy57 went through how this algorithm works and how it can get fooled. I seem to remember it samples at about 1 Hz and uses the average fuel spritz time divided by the speed sensor reading or something like that.
I’m channeling my late father, regarding computed values, who once watched a technical presentation of a guy using the an IBM mainframe for a complex Space shuttle engineering calculation, saying β€œ your first two eigenvectors are right, but you made a mistake on your third. Go find your code error”
CIK7
Post by CIK7 »
abscate wrote: 15 Mar 2026, 02:58 Somewhere buried in these pages Jimmy57 went through how this algorithm works and how it can get fooled. I seem to remember it samples at about 1 Hz and uses the average fuel spritz time divided by the speed sensor reading or something like that.
Sounds mathematically complicated to my mathematically incorrect brain.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I doubt the software is wrong or failed since it worked for decades. Likely a sensor is failing. With luck it will only impact your MPG display.
hausmeister
I mean, if you are concerned something is wrong, get an emissions test done and see if it passes that.
The only time I had extreme consumption the o2 sensor was bad. but that was not a display issue, it displayed and used a lot.
CIK7
Post by CIK7 »
Ill be installing a new ignition switch on Monday and doing a tune up on Tuesday. Ill let yall know if the switch does anything. That has been causing cluster related bugs.
CIK7
Post by CIK7 »
Okay, so I installed a new ignition switch yesterday and did a tune up today. I did not test the ignition switch before I did the tune-up, so I don't know if that is what fixed the sporadic mpg thing. However, it is working perfectly now. I would lean towards the ignition switch being the fix because all a bad electrical ignition parts system (sp, sp wires, dist cap&r, etc) does is cause MPG to be worse.
