First ...A thanks to Abscate! In another thread Abscate indicated that CARDONE rebuilt Calipers are Volvo. I can confirm that. I bought CARDONE rebuilts and they are indeed Volvo calipers.
Now here is where i need help (sort of): Does anyone have a trick to installing the springs on the outside of the caliper. I swear i fight those things everytime i put pads on the front. I can swap the pad, rotors etc, but I swear I spend more time trying to get that spring set up correctly.
any tips or a way to get that done would be super helpful!!
Brake Caliper Info and Question
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Has thanked: 2197 times
- Been thanked: 1850 times
Nope, I have done these many times and they either pop right in or they fight you every step. I generally fit it on the bottom first and then wrestle it at the top. I use a pair of adjustable pliers to old the top pin and force it into the top hole. Tap it into the hole with a small hammer.
Just make sure the holes for the pins are not clogged with paint or dirt first.
No magic!
No magic!
- Grantkat
ok my friend...i use the same method, hammer and pliers. Man i hate those things.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
Ok - funny side note..
last night I spent, I am guessing about 15 to 20 minutes trying to get the spring clip on only to have it pop off again and again...so I gave up, went inside and decided to tackle it in the morning. I went out about 10 minutes ago. and on the 2nd try, it snapped right into place.
time for more coffee and a good chuckle at my expense...
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
Yup, that sounds about right...............
- rolsen11
- Year and Model: 00 V70, 04 S60R
- Has thanked: 56 times
- Been thanked: 58 times
I use a flathead screw driver to pry the clip up and slide it down the shaft of the screw driver and into place. It takes a little bit of finagling to get the driver in the right position but it seems to work well for me.
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
- Been thanked: 4064 times
I clip on a needle nose vice grip so they don’t fly away. I got a nose hit once , which is memorable
- 15 Replies
- 6407 Views
Last post by wizechatmgr
- 1045 Views
Last post by bmdubya1198
- 635 Views
Last post by dosbricks
- 32 Replies
- 5441 Views
Last post by cn90
- 814 Views
Last post by br0dy519
