2009 C70 T5 -- backup camera?
susiemargaret
- Year and Model: 2009 C70 T5
- Has thanked: 1 time
- Been thanked: 3 times
is it possible to install a backup camera in my hardtop C70 T5 convertible? and if so, any recommendations? where would i get one, and who could install it (e.g., dealership, commercial mechanic, etc.)?
- Has thanked: 2212 times
- Been thanked: 1853 times
It should be possible to fit a camera to most cars. I just had one fitted by a Canadian national electronic store chain who have an automotive radio, speaker, etc., fitment shop. This was to a 06 V70 wagon. Not cheap but they have always done a good install for me. They typically have various cameras they can fit. I don't know if you have stores like Good Guys, Best Buy or sometimes specialist automotive installers locally should be able to do this.
Shop around and find the head unit you like as you need one that has a camera input. I went slightly higher end so that I have full Bluetooth input for streaming for Apple Carplay and Android Auto. Cheaper versions have a USB input requiring a connecting cable to connect to the Carplay and Auto functions.
Today you can also buy a mirror that clips over your rearview mirror that has the backup camera feed to it.
Just be wary of wireless units. They often have a time delay so what you see may not be real time. If you can learn to live with the delay you can possibly find a unit that you can fit yourself, but you will have to find out how to trigger the backup signal manually or even using a dashcam setup with front and rear cameras.
susiemargaret
thanks! i'll check at best buy and at a place that works on "high-end cars," including volvo (its actual name!).
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
I put a backup camera on my sons 1999 mustang convertible. Neil is on point. We bought a head unit with back up camera from Crutchfield.
On our setup the camera mounts to your license plate. that was key on his convertible. worked well.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
susiemargaret
thanks for the reassurance!
PS -- i love your signature line -- i have told complete strangers, it's never too late to get a convertible!
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Keep in mind that volvos may have sensitive electronics. It may trigger a low battery or bulb out or other annoyance. Some models are quirky with their electronics. You won't know till you try it. I put a dash cam type camera in s60 and triggered low battery light.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
susiemargaret
thanks! did the camera actually drain the battery or just trigger the light?
cuhfs
Just triggers the light. No effect on the battery or car operation.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
The back up camera just fitted to our 06 V70 is connected to the license plate light wiring to power it's own license plate light, and the trigger power is taken from the back up lights wire feed. It has not triggered any warning lights.
- Has thanked: 2865 times
- Been thanked: 1332 times
The 97 850R I just sold had a backup camera mounted to the license plate bracket/frame/holder. It was annoying because it was slightly in the way as I used the back tailgate latch. Slightly, not a dealbreaker.
It was not hooked up because the display was not mounted, so I can't comment on its actual performance. The wire I didn't take the time to trace from the tailgate, but I never saw it, so it was done well. It reappeared under the center stack, and the ash tray was simply removed/absent and the endpoint was somewhere in that area. All this work was done by the previous owner or the owner before him.
@susiemargaret if you find the system you're going to buy on Amazon, please use my Amazon link (top of the page) to buy it.
- 16157 Views
Last post by xiaofei204716
- 3083 Views
Last post by SuperHerman
- 2789 Views
Last post by RickHaleParker
- 3790 Views
- 2257 Views
Last post by babybluebug
