Hi Guys-
Was thinking of draining and re-filling the coolant in my older V70 since I have never done it as long as I have owned it.
I have 223k miles on her and I have owned it since 2017. I just looked in my owner's manual for the type and capacity,
and it does not list either.
I have been re-filling it on occasion with "Zerex G-05" phosphate free coolant, but when I went to an Auto Zone today all
they sold was stuff that was colored blue. The G-05 was basically clear in color. Is the blue stuff newer?
Also, can anyone tell me the full capacity of coolant? Thanks!
Coolant Change-out - 2002 V70
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 158 times
- Been thanked: 6 times
- Has thanked: 987 times
- Been thanked: 1078 times
Shop around. The Zerex G-05 is still available. It is what I use in modern Volvos and Mercedes.
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
Just did this with the blue stuff from Advance. I forget the brand but it was for "european" cars...volvo, bmv, etc.
I drained it out the bottom of the radiator. Probably put about 6-7 qts back in.
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
I would focus "re filling" part of your post first. Do you mean that your car is loosing coolant and you have to periodically add new antifreeze? If yes, than i would focus on finding the cause of such issue first(if it is headgasket, what the point to change antifreeze? ). However there might be multiple other areas where car might loose coolant. Zerex is a good brand, but volvo oem stuff is not expensive either. Add 1 gal of distilled water($2) and you are done.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
9-10 qts if you also open the engine block drain, its near the oil cooler.hu5ker555 wrote: 21 Mar 2026, 19:20 Just did this with the blue stuff from Advance. I forget the brand but it was for "european" cars...volvo, bmv, etc.
Mr. Detail
Thank you gentlemen!
- 3490 Views
Last post by RickHaleParker
- 2773 Views
- 21 Replies
- 1591 Views
Last post by Oro
- 11 Replies
- 16139 Views
Last post by RossJonnes
- 2897 Views
