Hi.
My 3.2l S80 2007 gives an P011200 + P011100 + P007100 error.
This indicated the Intake Air Temperature sensor 1 circuit input low or general fault
And the P007100 is the ambient temperature sensor fault.
Google on this intake air sensor brings me to “air charge temperature sensor”, part nbr 9445153
I have problems identifying the location of this part. Is somebody knowledgeable on this?
I did found the mass flow sensor and already replaced this last week, because an error code referred to that.
Regards,
Jan.
P011200 P011100 Intake air temperature sensor location
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
I might be wrong here(most likely i am ), i believe it is located on the intake manifold. On the left side towards the bottom. Close to the intake hose connection(opposite side).
P.s..maf sensor last week, iat sensor this week...what are we trying to fix? Do you have any drivability issues, obd 2 codes?
I will have a look this weekend. Thanks.
Mass flow sensor: a “friend” did the readout and concluded this was NOK. So replaced it, but maybe was not nessasary. Was a simple job.
The new readout was done by a professional in my presence.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
The internet is full of wonderful information
According to the AI
“ Volvo MAP sensors typically use a 3 or 4-pin connector, with standard wiring consisting of a 5V reference, ground, and a signal wire to the ECU. Common configurations include Pin 1 for 5V power, Pin 2 for Ground, and Pin 3 for the MAP Signal. A fourth pin, if present, is usually for the Intake Air Temperature (IAT)”
Good luck
Paul
According to the AI
Good luck
Paul
- 1511 Views
Last post by 454cid
- 4705 Views
Last post by EChem
- 192 Views
Last post by jreed
- 1129 Views
Last post by Talviomena
- 7920 Views
Last post by adrian22
